Error Database connect failed
funhall || http://funhall.cf/
** my error message**
After surfing a little on the website (2 - 3 windows) I get this message, sometimes I would be glad if you help loading it wrong, thank you very much already :heartbeat:
it works fine for me sir
refresh the page, sometimes it opens; thank you for your interest
maybe forum members help you
If I could understand why it turned out
can i know what cms u use because i test that on mine and check if it it cms problem or someother
yeah you are correct it happens after refresh sometime before
Can you try to debug your code in way to show exact connection problem? (i. e using mysqli_error() ) The error in screen shot is a code-generated error. Which is not configured to display exact problem
