Hello,
My Wordpress site is not loading, likely because my phpMyAdmin page doesn’t load either, error: “This page isn’t working”, but I get the error listed below on my site pages (http://whgl.42web.io/).
I’m guessing that there is some kind of an outage, since this error appeared without having made any changes to the site, but if anyone knows anything about this or can assist, that would be great.
Full page error:
Warning : mysqli_real_connect(): (HY000/2002): Connection timed out in /home/vol17_2/epizy.com/epiz_32014439/htdocs/wp-includes/wp-db.php on line 1753
Deprecated : mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol17_2/epizy.com/epiz_32014439/htdocs/wp-includes/wp-db.php on line 1785
Warning : mysql_connect(): Connection timed out in /home/vol17_2/epizy.com/epiz_32014439/htdocs/wp-includes/wp-db.php on line 1785
This either means that the username and password information in your wp-config.php
file is incorrect or that contact with the database server at sql302.epizy.com
could not be established. This could mean your host’s database server is down.
- Are you sure you have the correct username and password?
- Are you sure you have typed the correct hostname?
- Are you sure the database server is running?
If you are unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress Support Forums.
