i try add my the nameserver to my dmain but t says this?
Failed to save Nameserver list.
Nameserver error - ERROR: 901 Unexpected RCODE (target, entity, RCODE) (ns1.epizy.com ./107.189.11.47:53, my domain, REFUSED)
Nameserver error - ERROR: 901 Unexpected RCODE (target, entity, RCODE) (ns2.epizy.com ./198.251.86.152:53, my domain, REFUSED)
What is your domain name?
zeptonhostings.de this what you want?
Unfortunately, your domain is likely to work here, please see if you can get a refund from your registrar or buy a new domain from Namesilo, etc. Reason:
Before you can add a domain name to your account, you need to point it to the InfinityFree nameservers first. However, some domain providers show an error like this when trying to change the nameservers:
DNS Query Refused
If that happens, your registrar will tell you that the nameservers must be configured first.
What causes this issue
Before you can add your domain to your InfinityFree account, you need to verify you can control the domain. The usual way to do so right now is by setting th…
system
Closed
January 29, 2022, 11:04am
6
