Website URL
https://namkeen-e-bazaar.co.in/
This either means that the username and password information in your wp-config.php
file is incorrect or that contact with the database server at sql108.infinityfree.com
could not be established. This could mean your host’s database server is down.
- Are you sure you have the correct username and password?
- Are you sure you have typed the correct hostname?
- Are you sure the database server is running?
I’m facing this issue from yesterday , in wordpress sometimes options works sometimes this option comes
