INSERT command denied to user ‘epiz_23354995’@‘192.168.2.186’ for table 'registration’
this error are occure
That’s not an error message generated by MySQL, or by our servers. Which probably means your software is hiding the real error message.
In order for us to be able to effectively help you, can you please open the New Discussion panel, choose the Hosting Support Category and then copy the template from there. Then fill in the template, and paste it in a reply here. Please answer all the questions in the template so we can help you as effectively as possible.
no no , this problem can solved
check this error on my website “onlineparking.cf”
how to remove this Cloudflare support on my website
please reply me.
