Hello there,
That’s not possible for me to install or to upgrade prestashop 1.6 to 1.7; did you have this problem yet ?
Thanks
Hello there,
Thanks
Are you using the Auto Installer?
Yes with softacullous
Alright, what Error do you get?
The following errors were found :
And if i try to install 1.6 and then to upgrade, nothing happen…
That error means the software requires the InnoDB storage engine for MySQL, which is not available on free hosting (only premium hosting). So it looks like PrestaShop 1.7 cannot be used on free hosting.
ok thanks you
