Ok, so I still have an SSL certificate issue with my website (talkstaind.rf.gd), the admin told me to try installing a ZeroSSL or GoGetSSL but I need help on installing those!
Could someone help me install these certificates?
I have done a tutorial that may get approved soon, Have you done the CName Records?
To get a free SSL certificate from InfinityFree, you need to setup some DNS CNAME records on your domain name. This article describes how to do that.
Where do I set up the CNAME records?
The CNAME records should be set up with the DNS hosting provider of your domain name.
Most people will be using the InfinityFree nameservers ns1.epizy.com and ns2.epizy.com, or the byet.org nameservers. This means you can add the records to the control panel of the hosting account hosting this domain name. Th…
And
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your account. This article describes how to do that.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get this SSL certificate at a certificate vendor of your choice. InfinityFree also provides free SSL certificates from the client area , but you are free to use any other recognized SSL vendor too.
If you al…
If you are still stuck, please let me know the specific spot where you are stuck.
Thanks
system
Closed
March 11, 2022, 8:20pm
#4
