please i keep getting the error failed to connect to Mysql:Access denied for user ‘epiz_33895316’@‘192.168.0.210’ (using password:YES)…Have checked my password and database name all correct yet still having the issue pls i need help thankyou
I checked your website and it seems to be working fine from here. Where exactly on your site do you see these errors?
hi admin, I encountered the same error, you can check it out at http://chat2ai.e***y.com/test.php
please help, thanks
Access denied for user ‘epiz_33917567’@‘192.168.0.204’ (using password: YES)
Good, then please be sure to select your notification preferences at the bottom of the topic so you’ll be notified when we investigate this issue for @camangles.
If you want us to investigate this issue for your site specifically, then please create your own topic instead of replying to someone else’s.
I have created my own topic. Thanks.
