Unable to communicate back with site to check for fatal errors, so the PHP change was reverted. You will need to upload your PHP file change by some other means, such as by using SFTP.
cant update my files
plz help
plz help
@sumeetbalwade said:
Unable to communicate back with site to check for fatal errors, so the PHP change was reverted. You will need to upload your PHP file change by some other means, such as by using SFTP.cant update my files
plz help
ISS Kay Matlab,
You have to upload your files manually using FTP as bots can’t connect to IF Servers due to security reasons.
