hi how can i fix the bandwith error idk my domain ervery time i enter to give me the 503 error how can i fix this and the cpanel is have problem to login with some ip please answer me thanks
Bandwidth error? Provide domain name at least?
i mean the usage how many people can use site in same time
katufo
July 3, 2020, 2:55pm
#4
Please take a look at this KB’s:
One of the limits in the control panel is the inode limit. What is it, and what happens when you reach it? What is an inode? In short: every file and directory on your hosting account is an inode. Unix-like systems, like Linux and macOS, use...
One of the limits InfinityFree enforces is the “hits” limit. This article explains what a hit is, how you can control your hits usage and what happens if you exceed the limit. What is a hit? A hit is a simply request to a file on your website,...
One of the limits InfinityFree enforces is the Entry Process Failures limit, also abbreviated to Entry Process limit or EP limit. This article explains what an entry process is, what the limit means and how you can control it. What is an entry...
system
Closed
July 18, 2020, 2:55pm
#5
