Err, what issue? Can you please describe a bit more than posting three words and a screenshot?
Can’t you see the option cut is not showing properly?
You can also use FileZilla. Does the same thing.
Ah, now I see what you mean.
I’ll check it and forward the issue to the developers of this software. Please keep in mind that the file manager is not developed by us, so I cannot make any promises about if or when it will be fixed.
Can’t you see the option cut is not showing properly?You can also use FileZilla. Does the same thing.
I want to know FTPS server port.
Hi,
21 or 990
FTP over Explicit TLS can be done on the default FTP port: 21
Implicit TLS is deprecated and not supported on our servers.
