The link above shows how to redirect all traffic to https but i don’t have the permission to modify the .htaccess file on the server. can anyone help?
Most likely you are editing the wrong file. Perhap a screenshot of directory will give a clearer picture
You need to edit the .htaccess
file in the /htdocs
direcotry.
You need to edit the .htaccess inside the htdocs folder, try editing via FTP, it should work.
I use this on mine to force https:
Header set Strict-Transport-Security "max-age=31536000" env=HTTPS
RewriteEngine On
RewriteCond %{HTTPS} off
Is that the file that says DO NOT EDIT THIS FILE
at the top? And did you read it and determine that that’s the file you should be editing?
Sorry, I was trying to edit the file in the root directory.
It works now, thanks!!
