While others’ links look like this:
My links look like this:
What’s the matter?I just don’t get it
It depends on how you place the link.
If you put the link on a separate line, you get the card inlet. If you place it in-line, you only get the link text.
For example, if you do this:
Check out this post:
https://forum.infinityfree.net/t/forum-links-wonders/76745
It renders as:
If you do this:
Check out this post: https://forum.infinityfree.net/t/forum-links-wonders/76745
It will show as this:
Check out this post: Forum links wonders
Let me try it:
omg it works
thx admin!
