Your nameservers will be located on 123-reg.com under your domain name. There should be an option to change your nameservers from the ones provided by InfinityFree to the ones 123-reg have provided you with.
I am trying to direct Mail for my email address: [email protected]
so that it can appear appear on my iPhone.
I’ve contacted 123-reg who hold my domain: terrybraverman.co.uk
and they have replied thus:
Thank you for your reply. From what I can see, you only had the domain with us and there is no reference for any email address (mailbox) that was here.
***Also, the domain does not have our MX records which means that the wbe forwarding created here is not actually active. ***
When you pointed the domain to your website, you also moved the settings to be managed from their end.
This means that if you want the email forwarder to work and redirect emails to your hotmail address, you will need to add our MX records (email settings) on the domain.
This can be done only via your Website provider`s end.
For starters, your domain name is using 000webhost.com nameservers right now. If you want to control your DNS records through us, you’ll need to update your nameservers to ns1.epizy.com and ns2.epizy.com.
After that, you can set your MX records through the MX Records section in the control panel of your hosting account.
And please don’t create multiple topics for your question.
