When i connect to ftp using file manger i fill up username and pass and i click connect it shows: Error! Could not read line from socket
When i use filezilla:Answer:
> 220 ---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Answer: 220-You are user number 2118 of 6900 allowed.
Answer: 220-Local time is now 06:10. Server port: 21.
Answer: 220-This is a private system - No anonymous login
Answer: 220 You will be disconnected after 60 seconds of inactivity.
Command: AUTH TLS
Answer: 234 AUTH TLS OK.
Status: TLS Initialization ...
Status: Certificate verification in progress ...
Command: USER epiz_28883200
Answer: 331 User epiz_28883200 OK. Password required
Command: PASS **************
Error: Unable to connect to the server
same problem.
IP: 185.27.134.55
i had this problem on 3 other accounts
and this is the forth one
the other 3 account have the iPs which is down
but not this one.
any idea on what is wrong?
@OverloadedTech@toxic_toxic
Just saying “me too” dosen’t do nothing bug fill up the form. If you want things checked you need to provide a domain name. Also, ensure that the error message is exactly the same.
