I cant login with filezilla because of the outdated certificate
It’s a self signed certificate, yes. It’s not trusted, but it’s more secure than not using any certificate at all. However, FileZilla should show you a dialog with a warning. If you accept it, then you’ll be able to connect to FTP.
no i cant it is always outdated
Screenshot by Lightshot
If you click OK, it should allow you to proceed without further issues.
i found this issue, outdated certificate in the dialog Filezilla Client on Windows
In the ENCRYPTION drop down menu in your ftp site settings, choose "Only use plain FTP (insecure). That’s what I had to do.
You shouldn’t do that. It’s better to accept the invalid certificate than not use any certificate at all. Because even though the certificate is invalid, it still ensures the information is encrypted during transfer, which means it’s far better than not using any security at all.
