Same here… seems like the failure is in the ftp host itself. I too have input the correct hostname, username, password and even the ftp port.
I use WYSIWYG web builder and it has built-in FTP uploader. Last month ago the last update I made into my website. the FTP server works very well even though I reconnecting to it every few moments to check the .php files are working.
But now… I just maybe accessed it 3x then, the server…
*** START OF PUBLISH ***
Scanning publish folder…
Found 34 file(s).
Initializing FTP connection…
Checking host…
Host was successfully parsed.
Connecting to ftp.epizy.com…
Using PASV mode.
Internet Exception Error 12002
Details:
The operation timed out
Closing FTP connection…
Removing temporary files…
Publish failed!
*** END OF PUBLISH ***
Above is the error showed by the WYSIWYG Web builder built-in FTP uploader.
Then in FileZilla… the error is:
Status: Resolving address of ftp.epizy.com
Status: Waiting to retry…
@Matt75 said:
I can only find one place where I can change my password, at my Profile in the Client Area.
That’s the password I’m using.
That’s not the right password.
Go to your Accounts list, click Manage next to the account you want to login to and then click the Password tab. There you’ll find the password for the specific hosting account, which is also the password you need to use for the FTP connection.
