FTP connection timeout
I believe I’m not doing anything wrong here… is there any special setting?
this is all log or not?
somewhere below do you see that is written refused
or error number?
first check this Help, I cannot connect to FTP - Docs - InfinityFree Forum
or error number?
How to upload files with FTP - Docs - InfinityFree Forum
no error message, Filezilla tries twice and stops there, no error number
I checked both links you provided, everything is ok
and yes, it is all the log
I created permissions manually with the firewall for filezilla as well, but seems like is resolving the name so… no issues.
OK - thank you for info
please try again but with detailed log Logs - FileZilla Wiki
and paste log here (notice to not include any private information)
so…tomorrow morning (7-9h CET) admin, me or someone else will look
got a different answer now, but getting disconnected yet
2018-03-17 09:59:01 11988 1 Status: Resolving address of ftp.epizy.com
2018-03-17 09:59:01 11988 1 Status: Connecting to 185.27.134.11:21…
2018-03-17 09:59:01 11988 1 Status: Connection established, waiting for welcome message…
2018-03-17 09:59:01 11988 1 Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
2018-03-17 09:59:01 11988 1 Response: 220-You are user number 716 of 2900 allowed.
2018-03-17 09:59:01 11988 1 Response: 220-Local time is now 15:53. Server port: 21.
2018-03-17 09:59:01 11988 1 Response: 220-This is a private system - No anonymous login
2018-03-17 09:59:01 11988 1 Response: 220 You will be disconnected after 60 seconds of inactivity.
2018-03-17 09:59:01 11988 1 Command: AUTH TLS
2018-03-17 09:59:02 11988 1 Response: 234 AUTH TLS OK.
2018-03-17 09:59:02 11988 1 Status: Initializing TLS…
2018-03-17 09:59:22 11988 1 Error: Connection timed out after 20 seconds of inactivity
2018-03-17 09:59:22 11988 1 Error: Could not connect to server
2018-03-17 09:59:22 11988 1 Status: Waiting to retry…
2018-03-17 09:59:27 11988 1 Status: Resolving address of ftp.epizy.com
2018-03-17 09:59:27 11988 1 Status: Connecting to 185.27.134.11:21…
2018-03-17 09:59:27 11988 1 Status: Connection established, waiting for welcome message…
2018-03-17 09:59:27 11988 1 Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
2018-03-17 09:59:27 11988 1 Response: 220-You are user number 733 of 2900 allowed.
2018-03-17 09:59:27 11988 1 Response: 220-Local time is now 15:53. Server port: 21.
2018-03-17 09:59:27 11988 1 Response: 220-This is a private system - No anonymous login
2018-03-17 09:59:27 11988 1 Response: 220 You will be disconnected after 60 seconds of inactivity.
2018-03-17 09:59:27 11988 1 Command: AUTH TLS
2018-03-17 09:59:27 11988 1 Response: 234 AUTH TLS OK.
2018-03-17 09:59:27 11988 1 Status: Initializing TLS…
2018-03-17 09:59:47 11988 1 Error: Connection timed out after 20 seconds of inactivity
2018-03-17 09:59:47 11988 1 Error: Could not connect to server
why it takes longer than 20sec I do not know
maybe admin knows the answer
but try this
Open FileZilla> Edit> Settings> Timeout in Seconds: 20> change to> 200
and test
last option is to use plain FTP https://forum.infinityfree.net/discussion/comment/11102#Comment_11102
