Yes. filemanager.ai gives 403 ngnix errors.
Solution? Connect with
- mftp.infinityfree.net
ftp.epizy.comServer offline (reported by sophos firewall) (FTP CONNECTION SERVER)- files.dreamhost.com (quite slow)
NOTICE: ftp.epizy.com
is not pointing to the file manager’s server, so you might have to use the first and the last links you sent to connect to that FTP server via the browser, else use FileZilla. Also, it seems like the file manager problem has solved, at least for me, as I can connect to filemanager.ai/new/ just fine and it doesn’t throw that error.
i too believe the issue is fixed.
