FTP not connecting
Username: epiz_32188471
Connection attempt failed with “ECONNREFUSED - Connection refused by server”.
Status: Disconnected from server
Status: Connecting to 62.24.138.17:21…
Status: Waiting to retry…
All connection details have been entered correctly and control panel activation has been done but still there is no ftp access. Same result using both filezilla and coreftp.
Hi and welcome to the forum
Not well resolved - it should be this IP 185.27.134.11
so please use IP directly (as an address) instead of ftpupload.net
The cause - may be because of your ISP or you’re using a VPN that points in the wrong direction (bad IP).
Thanks. Seems to have fixed it.
