Status: Resolving address of ftp.epizy.com
Status: Initializing TLS…
Status: Waiting to retry…
Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response: 220-You are user number 659 of 2900 allowed.
Response: 220-Local time is now 19:29. Server port: 21.
Response: 220-This is a private system - No anonymous login
Response: 220 You will be disconnected after 60 seconds of inactivity.
Command: AUTH TLS
Response: 234 AUTH TLS OK.
Hello
maybe this helps you https://forum.infinityfree.net/discussion/comment/11102#Comment_11102
@Admin said:
The FTP server itself is working fine.
I don’t think you’re the first ever to have this issue, but we’ve never been able to reproduce it or figure out why some people have issues connecting to FTP.Perhaps it’s poor configuration on your end or an issue with your internet provider, maybe it’s something on our end. Until we can confirm on our end the issue exists, we can’t do anything about it.
The network logs suggest it’s an issue setting up the SSL connection. Do you get any prompt regarding an SSL error?
Hi FTP does not work at all, … I tried anyway, … I looked on youtube if there was something extraordinary …
but nothing worked, … check if you are registered there … FTP Information
Connection details for FTP clients. help
FTP Username epiz_21706485
FTP Password (the account password)
FTP Hostname ftp.epizy.com
FTP Port (optional) 21
tem alguem ai pra responder?
Is someone there to answer?
See:
