Error:
GnuTLS error -110 in gnutls_record_recv: The TLS connection was non-properly terminated.
Status:
Server did not properly shut down TLS connection
Error:
Could not read from socket: ECONNABORTED - Connection aborted
Error:
Disconnected from server
5 min ago i was able to connect to my FTP (Fileziller) using the same credentials.
For whatever reason. i uploaded my php index file to server again.
then my connection went down?
Dont know why, hoping the error is a common one.
trhrows this error in Fileziller when i try to connect.
Error:
Status:
Error:
Error:
Resolving address of ftpupload.net
Status: Initializing TLS…
Status: Verifying certificate…
Status: Logged in
Status: Retrieving directory listing…
Status: Directory listing of “/” successful
Then the error after 1 min
Response:
421 Timeout - try typing a little faster next time
Error:
Status:
Error:
Error:
Admin
April 8, 2021, 5:02pm
#4
That’s normal. Our FTP server is quite aggressive when it comes to shutting down inactive connections.
Stress on the inactive part. As long as you’re actively using the connection for folder navigation or file transfers, the connection will not be interrupted. But if you don’t use the connection for a while, the server will close it to free up connection slots for active users.
So you can just reconnect to the FTP server and continue from there.
yes i sorted that issue. it was not a problem after all,
it was my files that where the problem.
system
Closed
April 23, 2021, 5:30pm
#6
