http://groupf.epizy.com/?i=1
Hello, I’m trying to get FullCalendar to work with my website hosted at InfinityFree. The calendar should appear below the header image but could never get it to work.
errors/404/:1 Failed to load resource: the server responded with a status of 404 ()
jquery-3.6.0.min.js:2 jQuery.Deferred exception: Calendar is not defined ReferenceError: Calendar is not defined
at HTMLDocument. (js/script.js:20:3)
at e (jquery)
at t (jquery-3.6.0.min.js:2:30340) undefined
S.Deferred.exceptionHook @ jquery-3.6.0.min.js:2
jquery-3.6.0.min.js:2 Uncaught ReferenceError: Calendar is not defined
at HTMLDocument. (script.js:20:3)
at e (jquery-3.6.0.min.js:2:30038)
errors.infinityfree.net/:1 Failed to load resource: the server responded with a status of 404 ()
Now the error message seems to be different, initially it was that Calendar in script.js was not defined.
I have tried multiple ways and have read all the guides on the internet and can’t figure it how to get FullCalendar to work and be displayed. The part that connects the calendar functions to MySQL work but calendar itself is not displayed.
When I try to run a sample Fullcalendar PHP and js locally, it works. When I tried to integrate sample code with my website it didn’t work. So I’m really lost.
Could it be about the order of scripts being loaded?
Thank you in advance for your help!
