after installing the Starter Templates and trying to activate Elementor I get this error:
Plugin could not be activated because it triggered a fatal error. Warning : require(/home/vol11_1/epizy.com/epiz_31977611/htdocs/wp-content/plugins/elementor/includes/plugin.php): failed to open stream: No such file or directory in /home/vol11_1/epizy.com/epiz_31977611/htdocs/wp-content/plugins/elementor/elementor.php on line 54
And i cannot install any themes because of this. pls help
In addition to the above, it seems that your Elementor plugin is corrupted. Please try re-installing it.
If you’re unable to successfully install it through the WordPress admin, you can perform a manual installation instead by uploading the files through FTP. WordPress’ built-in installer tends to break on larger plugins due to account/server limitations.
