Status: | Waiting to retry… |
Status: | Resolving address of ftpupload.net |
Status: | Connecting to 185.27.134.11:21… |
Status: | Connection established, waiting for welcome message… |
Response: | 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- |
Response: | 220-You are user number 307 of 6900 allowed. |
Response: | 220-Local time is now 08:47. Server port: 21. |
Response: | 220-This is a private system - No anonymous login |
Response: | 220 You will be disconnected after 60 seconds of inactivity. |
Command: | AUTH TLS |
Response: | 502 AUTH TLS OK. |
Command: | AUTH SSL |
Error: | Could not read from socket: ECONNRESET - Connection reset by peer |
Error: | Could not connect to server |
Did you try all the steps from this article already?
No still no working
No, it’s not working anyhow, so please help me to make it working
Are you also unable to connect to the server while using a VPN? The logs indicate that the initial connection succeeds, but fails after trying to enable TLS encryption. This is usually caused by a problem in the connection handling in your router. If you have access to the router, it may have an FTP ALG setting which you can toggle to fix this.
