note
I’m putting this in Informal because if I put it in Community Guides it will get rejected… reply if that’s not ok.
Do you want Flarum on InfinityFree?
Here’s how to do it:
- Go to https://freeflarum.com/ and create a forum
- Then, go to your Control Panel and create a subdomain of your domain (like forum.yourdomain.com)
- When you have created your FreeFlarum forum, go to ‘Settings’ on the FreeFlarum page. (FreeFlarum | Settings)
- Then scroll to ‘Custom Domain’ and enter your subdomain of your domain (forum.yourdomain.com)
- Don’t click ‘Save’ yet! Go back to your control panel and go to CNAME records.
- Once there, add a CNAME record in this format:
Record Name: (your subdomain name like ‘forum’), Domain: (your main domain), and Destination: (yourforum.freeflarum.com) - Once done, wait 1-2 minutes, then go to your FreeFlarum settings and click ‘Save’. If it gives a success message, then you’ve done it! Visit your Flarum forum at forum.yourdomain.com (or the subdomain you created)
NOTE: This can only be done with custom domains (like Freenom domains or NameCheap domains)
If you have any questions or errors, feel free to reply below and I’ll see if I can fix them
