There are some people having trouble with the vPanel Kopage Sitebuilder,
The issue is the sitebuilder always say:
Used domain (domain example), doesn’t seem to point to this FTP account.
But I have found a way why this always occur:
First of all don’t use your client area username (e.g. user), use your vPanel username (e.g. epiz_12345678).
Second, in the Domain Name part don’t use 185.27.134.11 or ftp.epizy.com or ftp.yourdomain.tld, you should put your domain name there like mydomain.tld.
Third, put your email address.
*If unsuccessful:
First, all the files that the sitebuilder put into your directory should be deleted,
The kopage files should include this:
admin, inc, index.php and etc…
Second, Go back to kopage and try again
*If want to request you to upgrade pro version or it has watermark:
I don’t know but I think Admin can help you with this…
If you have any question or a part of this discussion that you do not understand,
Please reply to this discussion and I will reply soon,
I will be gone for 6 hours estimated today cause me and my classmates are going to have a reunion with our teachers,
So I cant reply to questions within this time…
Admin told me I am SUPPOSED to put in the IP address or ftp address.
Now we aren’t supposed to?
Who am I supposed to listen to?
And EVEN YOU SAID SO IN THAT THREAD.
WHAT.
@Jenova Sorry it was my mistake…
Try this and it will work and I also use this method for awhile now without any issues about “This domain doesn’t seem to pint to this FTP account”
@UnknownLolz said: @anon63078885 the only problem there is it did not created the data folder as what I see in your picture… So you can try again!
It even happens to me too!
WHAT.
I can understand the confusion, but what @UnknownLolz wrote about the domain name is right here.
What’s supposed to happen is, you need to enter the details specific to your website:
Username
Password
Domain name of your website
Optional subdirectory
The FTP hostname should be set correctly by us. It’s the same for all accounts anyways, so there is no reason why you would have to enter it yourself.
And if you would be required to enter an FTP hostname, at what part would you specify which of the multiple domains on your account should get the new website?
The FTP hostname is needed so the website can be uploaded and you can use the FTP credentials to login the website later on. The former already works, the latter doesn’t, due to so far unknown reasons.
@Jenova said:
Now I get this when I try:
I think something is wrong, configuration side.
Possibly, but the builder code is encrypted and sparsely documented, so it’s impossible to figure out why it breaks.
