All of this crap cause free webhost disable the php mail function all I wanted to do was to set up a site to do some surveys
This looks like the specific article:
I was actually thinking if DMARC records before, not DKIM, so @wackyblackie is correct.
You will need a custom domain if you want to use Cloudflare.
You can still use Gmail SMTP (Or any other SMTP service) with the free PHPMailer library. Check out the GitHub project below.
DKIM records can’t be set through us, so I would recommend to try a provider where you don’t need to setup DKIM TXT records yourself. I know SMTP2GO only needs some CNAME records to be set up, which means it can be used with your hosting here without using a separate DNS provider.
