This error keeps showing up since 1 week ago, I tried to do everything to fix it, I already checked the topic about this error and i tried to do every specific thing they said, but nothing happened so far.
It would be very much helpful if you could provide more information or could you please let us know your domain?
http://www.saegrpg.com/index.php?/forums/, and now i can see another error HTTP ERROR 500, this error just showed up 2min ago.
@UnknownLolz
hmm? any kind of help?
@Evan1901
Hi,
It looks like your website has a broken code on it or the server can’t handle your code maybe it’s just to heavy.
Also what Forum Software did you use?
@UnknownLolz
An error 500 and 502 are very different and have different causes. A 500 response usually means that your website code crashed. This could be caused by anything, but figuring out what the actual error message is is the best place to start: https://infinityfree.net/support/http-error-500/
@UnknownLolz said:
@Evan1901
Hi,
It looks like your website has a broken code on it or the server can’t handle your code maybe it’s just to heavy.Also what Forum Software did you use?
actually i use IPS
@Evan1901 said:
@UnknownLolz said:
@Evan1901
Hi,
actually i use IPS
Ouch, that’s expensive. Do you have a license for that? Note that using pirated software on here is strictly forbidden and if we find such software, your account will be terminated without any opportunity of recovery.
