You have no choice
cant i just delete the app folder and just leave the htdocs instead?
Login to FileZilla, the online file manager will probably not work for the next steps
If you are allowed to, delete the âappâ folder. If you are not allowed to delete it, rename it to âdeletedâ
Create a new folder and name it âhtdocsâ
Upload your files into the new âhtdocsâ folder you created
now i am trying to connect to my ftp via filezilla and it says:
Response: | 421 Too many connections (10) from this IP |
Error: | Could not connect to server |
Status: | Waiting to retry⌠|
Is that the full log? Can you share the entire thing?
thats just it, maybe i have to wait a few minutes to retry again
It looks like FTP was down for about 60 seconds. It should be working now
Response: | 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- |
Response: | 220-You are user number 281 of 6900 allowed. |
Response: | 220-Local time is now 12:07. Server port: 21. |
Response: | 220-This is a private system - No anonymous login |
Response: | 220 You will be disconnected after 60 seconds of inactivity. |
Command: | AUTH TLS |
Response: | 234 AUTH TLS OK. |
Status: | Initializing TLS⌠|
Status: | TLS connection established. |
Command: | USER epiz_32378755 |
Response: | 331 User epiz_32378755 OK. Password required |
Command: | PASS **************** |
Response: | 421 Home directory not available - aborting |
now i could login via online file manager but not filezilla
Thatâs because you messed up the account
See this???
No, FileZilla should still load without the htdocs folder, since it is the root folder, not the Home directory.
Try doing the steps above in the file manager then @R0ot3dDr0id
Success!
Your account is now being deactivated!
Can i just create an account after it says deactivated or deleted? i dont think it takes upto 60 days for removal.
after new account i think its ok now?
Looks good.
With deleted accounts, they enter a âdeactivatedâ state immediately, and no longer count towards your 3 account limit. After 60 days, they will be removed from your account
is the server offline? My site says Hmmm⌠canât reach this page
emchatnetwork .comâs server IP address could not be found.
A dig
command shows that your domain is not pointing to InfinityFreeâs servers.
I can see you are using Cloudflare, so please add the following records there:
RECORD #1
TYPE: âAâ
CONTENT: â@â
NAME: IP address from app.infinityfree.net
RECORD #2
TYPE: âAâ
CONTENT: âwwwâ
okay thanks, i got it working now
