Give us more info, like the website and what was the last thing you did to the website.
Welcome to the forum @ggwpgasdsadas! Please follow the template in the hosting support option.
The HTML content returned looks like the start of a page and then it just stops. If I look at the Network tab in my browser, I see the status code for the page is 500, which probably means there is PHP code there which crashed.
So this is a good place to start: HTTP ERROR 500 - InfinityFree Knowledge Base
sorry I’m newbie, can someone help me in uploading my site? I dunno to do it, I’m just watching tutorial but I cant follow it. below are some files
Please follow along with the article linked below. If you get stuck, please let us know where in the process.
Thanks.
can you help me in uploading my site sir? I am also a filipino
To upload, use a FTP (search filezilla on google and download it, then login into the server which the login info is in infinityfree client area…). Then you need to select all of those files (click on the first one and then hover over last item and press shift click.) Then you drag and drop those files into the htdocs folder which are in the right side of filezilla.
Go to File Zilla and then download the FTP login with your credentials in your Client Area then take all the files and upload them to the htdocs folder.
all of my .php is blank page
Rename your main file to index.php. It should load then
Check your PHP code or .htaccess
On the first line it says “mysql” and “No such file or directory”. That can only mean one thing:
