Help!?
last question, why if I click the link to my website its redirecting me to my localhost
Edit your config.php file. Where you see “localhost”, change it to your domain name.
It works, thank youuu!
Try reupload with filezilla
Problem Solved
Why image is not showing when i transfer my site to https from http, how to fix that?
When I use http its showing.
Most likely mixed content. You need to update whatever software that is to use HTTPS.
On https some image are showing but the others are not, all image on http is showing
That’s what I mean by mixed content. You need to tell that script you are using to use SSL/HTTPS. If you don’t know how to do this, can you provide us with the script’s name and source site?
Thanks.
I dont know hot to do it, what script’s name and source site? pardon Im newbie
What is running your site? Is it self-coded, WordPress, etc.
Where can you download this software?
Sorry, I should have been more clear :slight_smile:
Best Regards, I hope we can see the problem
@ggwpgasdsadas
I hid the URL that leads to gdrive
Do not share config file , dbcon, or any other sensitive file publicly because it contains access data (user, pass, etc.)
also be sure to change them now (since 8 hours have passed ) because someone will hack your website !
sorry, I’m desperate to fix my website problem immediately
That’s no reason to expose your personal information. Can you please answer the questions I asked earlier?
Thanks!
3 posts were split to a new topic: I cant access my database
