whats going with softaculous today
every time i automatically logged out from cpanel when i trying to install wordpress
You tell me!
softaculous also not loading properly and when i reload the page its logged out every time when i reload the page .
yes it says ip has changed please login again
first time i am facing this type of problem
and when i trying install wordpress. sriptinstall.rocks:2082says connection was lost
@sam111 said:
softaculous also not loading properly and when i reload the page its logged out every time when i reload the page .yes it says ip has changed please login again
I already suspected so. That’s a common issue which has been documented here: Docs - InfinityFree Forum
i cant able to do this
before i was using a 4g wifi device
now i am using a 4g phone
is says ip has mismatched on both device and phone
please help me
is says ip has mismatched on both device and phoneplease help me
Are you using VPN? if yes, then disable it and then login to vPanel
i am not using vpn bro…
i am facing 1st time this type of problem since i am using infinity
i can login to my cpanel
but cant install wordpress through softacolous
it stopped after 2%
Where did you signed up with IF? On your Laptop? Phone?
@sam111 said:
it stopped after 2%
Maybe you are on Dynamic IP Address and your ISP is resetting it in a short amount of time…
Try follwing what is said in this article: Docs - InfinityFree Forum and/or try using a reliable VPN to login.
The VPN that comes with Opera might be a good free solution.
today i have manually upload all wordpress file and create mysql database. this time also its not working !!https
Do not use localhost!
Your SQL server is written at the MySQL Databases section of your panel, go there and use this instead of localhost.
localhost is mostly used by premium hosting as database hostname but on free hosting your database host is mentioned in the sidebar of your vPanel as said by @ChrisPAR
and what about table prefix?? Its remain same as wp_?
still having the same problem table prefix must not be empty
Whatever you want it to be! Check your database in phpMyAdmin to see which prefix is used.
there is no table
