I’ve uploaded my file to htdocs for hpknodik.com but my site is still not working.
Your DNS does not seem to be set up properly. Go to your Domain Name Provider, and under Nameserver section, change your DNS to:
Wait for sometime and re-check. The issue should be solved.
Also check:
https://infinityfree.net/support/how-to-use-infinityfree-nameservers/
My website is still not working. hipknodik,com
It looks like your nameservers are set correctly and your account is active, but the DNS records seem to be missing from our nameservers. Can you please try to remove the domain from your account and then add it again? That should add the missing records.
how do I do that?
Go into your control panel, go to the Addon Domains section, delete the domain from there, and then add it again on that same page.
