Hello,
Please Can Anyone Provide Me The Correct Nameserver and the Shared IP which is the Most important to connect my Godaddy Domain.
So I kindly request everyone and the admin to please tell me the correct procedure to connect my Godaddy domain with InfinityFree Host.
As per Godaddy I need to Get the correct Nameservers and the Point IP/Shared IP.So please help Me out.
I would be very Thankful.
You can find your nameservers in the control panel. You can find the IP address by following this guide: Docs - InfinityFree Forum
Thank you for your quick reply.Actually Admin I used this IP address but I was Unable to configure my godaddy domain and the godaddy executive told me to get the correct nameservers and shared ip from the hosting.
So tell me the procedure to get shared IP of server.
If you provide me the procedure I will be very help full.
Hello Admin,I am Using this name servers are :-
ns1.rf.gd
ns2.rf.gd
and the error comes that the domain is no longer parked with godaddy.com
so I need to change my hosting server.
If you can provide me the correct nameservers with share ip than I will come back to your server as my one site is hosting on your site a I like it
You need to point the domain to our nameservers OR use GoDaddy’s nameservers with our IP address. If you just want your domain name to work, just point your domain name to our nameservers and don’t touch Go Daddy’s DNS controls. Only if you need advanced DNS controls or have another reason to specifically use Go Daddy’s should you move away from our nameservers.
Admin,
Just tell me that what should I do to get the my Point To IP
Please tell me.
@movieshub said:
@Admin said:
You need to point the domain to our nameservers OR use GoDaddy’s nameservers with our IP address. If you just want your domain name to work, just point your domain name to our nameservers and don’t touch Go Daddy’s DNS controls. Only if you need advanced DNS controls or have another reason to specifically use Go Daddy’s should you move away from our nameservers.Admin,
Please tell me.
Have you checked this article already: Docs - InfinityFree Forum
