i perchased my domain in godaddy and i want to connect my domain with infiinity free hosting so i want to know how i connect my domain with infinity free hosting.
i also check to change the nameservers.
godaddy nameserver was changed but then i face the IP probem.
this error was shown of screen “IP ADDRESS CAN’T FOUND”.
This is actually looks like this issue, but I can’t say for sure: Unable to set nameservers: DNS query refused
Actually, I think your nameservers were set correctly, but you just need to wait a bit for the settings to become active. So I think this is the relevant knowledge base article: https://infinityfree.net/support/why-doesnt-my-domain-work/
Soo when this problem will be solved
I am also wait aprox 100+ hours but “server IP address could not be found” this error is showing in the screen.
Provide website link, please
And if that article doesn’t help you, please post a URL like @MrJunior said, so people can actually check things rather than guess what could be the issue.
@Admin said:
Actually, I think your nameservers were set correctly, but you just need to wait a bit for the settings to become active. So I think this is the relevant knowledge base article: https://infinityfree.net/support/why-doesnt-my-domain-work/And if that article doesn’t help you, please post a URL like @MrJunior said, so people can actually check things rather than guess what could be the issue.
Your nameserver right now is:
alla.ns.cloudflare.com
charles.ns.cloudflare.com
Cloudflare is not InfinityFree I can tell, whatever if your nameservers just can’t change to InfinityFree - my first answer for you.
If you have changed them to cloudflare just to do some tests or smth like that - change them back to InfinityFree so you can start hosting it here.
i want to ask u where i can found my all DNS records like A,AAAA,CNAME,MX, IP ADDRESS etc records in infinity free
Your domain will not work with InfinityFree if your domain isn’t added in your vPanel (nameservers needed), you’ll be just redirected to suspendeddomain.
But you can find information about IP here: How to find the IP address of your account
@MrJunior said:
Your domain will not work with InfinityFree if your domain isn’t added in your vPanel (nameservers needed), you’ll be just redirected to suspendeddomain.But you can find information about IP here: How to find the IP address of your account
i fill correct ip address in my godaddy DNS records and wait aprox days so why this erroe (ip address can’t be found) shown in my screen
As I said in my message, your domain is being redirected to suspendeddomain.org
and then to suspended-website.com
. Please read my message again, also this information is explained in knowledge base article I’ve reffered to, how do you read?
(and yes, dns applied for me and your domain does redirect)
@MrJunior said:
As I said in my message, your domain is being redirected tosuspendeddomain.org
and then tosuspended-website.com
How to add my domaain in vpannel
