for example, abc.com to localhost ? right?
i followed your guide and after setting up database when i go to install wordpress on it it says Error establishing a database connection
Yes, you need to change the credentials in the wp-config.php file.
which credentials should i replace?
You new localhost database credentials. You would’ve created them right?
i was to create them but it showed me database error in the browser
You need to do it from the WP-config.php file
but what credentials should i replace there??
The new database name, username, password. And change the hostname to localhost
