hello i just want to know how can i get a hosted smtp information, because yandex360 dont have this protocol and thank you !
InfinityFree does not provide mail server, and does not have any SMTP servers that you can use. Also, Yandex (Like every major mail service) does provide SMTP.
o thank you
If you are using byet or epizy nameservers, you can add it in the control panel (Under “SPF Records”). You can alternatively add Cloudflare to your website to add a true TXT record.
Yes but cliudflare, to add 8t i have to change my dns nameserver
Correct. You can follow the guide below.
