How can I record txt on a free hosting?
You can’t create other types of TXT records on free hosting; the only TXT records that you can set up are SPF ones. If you also want to apply a DKIM TXT record, you could use your own nameservers, like Cloudflare (instructions shown on the following post) or your domain registrar’s ones, to set up that TXT record with them, but that requires that you manage your DNS records, or upgrade to Premium Hosting as it offers full DNS management options.
You can also change your domino’s nameservers to CloudFlare’s after adding the domain to you hosting account, and then point the domain to your account’s main domain. Then you can use CloudFlare to create TXT records, as well as most other kinds of DNS records on your domain.
