i tried uploding WordPress Zip file but could’t upload succesfully, its getting stuck in login.php (sub folder)…
For starters, the easiest way to install WordPress is by using Softaculous. That way, you don’t have to worry about uploading files and setting up databases in the first place.
However, if that’s not an option for you, can you please explain more about the issue you’re experiencing. For example, you say you’re using “FTP file manager”. But “FTP” and “file manager” are different ways to upload files. Do you use a desktop FTP client or a web based FTP client (and if the latter, which one)?
