How do I issue another certificate from different provider while I already have a valid ssl instal'd
My website is mylifesbeauty.ga I am just trying to learn some web development but It won’t help that much on troubleshooting I think.
I have already issued a ZeroSSL certificate using Infinity Free, Is there a way to install a different one (Let’s Encrypt) while the first one is not expired…
(I used "Instal’d " in the title because there was not enough space)
Just install the private key and SSL cert from Let’s Encrypt over the existing one. (Delete existing SSL cert from VPanel first)
I can’t delete existing SSL.
You can’t. First upload the new Private Key, then same for certificate. It will replace the old cert.
I tried, whenever I try to see the key of Let’s Encrypt it redirects to ZeroSSL
