First of all, so sorry for my stupidity! My daughter and I are trying to learn how to make a website. We’ve succesfully created a domain name, updated name space, created infinityfree account, and downloaded wordpress.
But, we can’t work out how to open wordpress/use it to create a website (I assume editing a theme) now it is installed?
I know this is the worst question ever!
Simply go to your website and add /wp-admin after your domain name. Login with credentials and you good to go.
Eg: www.example.com/ wp-admin
Oxy
May 28, 2020, 7:35pm
3
@iambalrog
Hi, a few confusing terms are contained in your post so we’ll process them just in case
iambalrog:
name space
my first thought was that you are a programmer let’s say C++
but you probably mean “nameservers”
there was no need for that - this is how it can be installed
On InfinityFree, it’s very easy to create your WordPress website. To create your WordPress site, follow these steps. Login to your control panel by clicking the login link from the client area. Enter Softaculous Apps Installer from the control...
what I’m not sure about is whether you really installed it or just downloaded it.
if not installed - follow the instructions above
iambalrog:
create a website
here are some beginner instructions
don’t say that! - it is better to ask than to do nothing
system
Closed
June 12, 2020, 7:35pm
4
