good night, I have an error, use softaculous to install the humhub and I have an error with Humhub every time someone tries to register on my website the same thing happens the error
escapeshellcmd() has been disabled for security reasons
And the truth is I do not know how to solve it, I hope your quick answer, thank you very much.
The escapeshellcmd() is typically used in conjunction with executing system commands on the server. However, system commands are blocked on InfinityFree, so the functions related to them are as well.
As for why HumHub uses this function to begin with, I don’t know. Maybe the script requires shell access. If so, those functions would not work here.
