How I can prevent exploiters from copying my website?
I have some exploiter are copying my website How I prevent them using PHP
PHP source code is not visible - but only the generated content.
And to some extent with that you can hide some internal actions.
But actually in case of theft, you are left with this option:
Discover who is hosting the website that stole your design or whole website. Fill the formal DMCA notice and send it to the service provider. If there are proofs asserting your claim, most hosting firms will take down the copycat to avoid getting pulled into a legal brawl.
I can’t On my main website not ksieo.me on https://flcgen.xyz I ge a lot of members like 10K+ Daily
If you do not want people to see the contents of your folders
create in root of htdocs file named .htaccess
and put this code in it
# Disable Directory Listings in this Directory and Subdirectories
# This will hide the files from the public unless they know direct URLs
Options -Indexes
use monstaFTP (file manager) from the client area
because many text editors can add BOM or wrong charset
or create a dummy index.html file (in every dir in which you wish)
purely to serve something instead of listing
