How to active SSL for subdomain
My website URL is:
What I’m seeing is:
I am trying to enable SSL Certificate.
I’m using this software:
I am using the WordPress
Additional information:
Niraj
You unfortunately cannot get a SSL certificate for a subdomain.
Yes , Can share the information how to get a SSL Certificate
If you do somehow get a SSL certificate for it. here is the article to install an SSL certificate.
You will need to enable redirect to https, because it won’t do it automatically.
Also all resources must be loaded and used over https, so update your images, JS, CSS, etc. to use https.
