How can I add a txt record to my domain using infinityfree?
Hi there,
You cannot add a TXT record to your sites using just InfinityFree.
You will have to add your domain to a DNS service provider like CloudFlare to do that by changing nameservers.
The proccess will be esay and there will be no problems.
NOTE:
Do not use CloudFlare from cPanel because if you do you won’t be available to change it.
@ChrisPAR said:
@samtaber said:
How can I add a txt record to my domain using infinityfree?Hi there,
The proccess will be esay and there will be no problems.NOTE:
So how would I go about doing that? Would I not use infinityfree?
Do not use CloudFlare from cPanel because if you do you won’t be available to change it.So how would I go about doing that? Would I not use infinityfree?
You will, just transfer your website on CloudFlare. You will be guided on how to do it step by step when you signup there and add your domain, if you want any help please inform me.
