Can I ask how do you add cname, srv, a records?
You can add cname records using the VistaPanel, you would have to use CloudFlare to add a and srv records.
how?
Sign up for Cloudflare and add the domain there. After that select the free plan, confirm that the DNS records are right and change the nameservers to Cloudflare ones from your domain registrar’s nameservers management panel.
Then go to the DNS Panel and set your records there.
Well, whenever I set my domain’s nameserver to cloudflare, the website becomes down.
Then add an IP address that points to your hosting account’s IP.
what do you mean?
So I need to create an A record?
Use this article;
TO find the IPv4 address, then add as an A record
