How to configure domains from no-ip.com?
My domain is registered and managed by no-ip**.com.
Because no-ip
.**com is my domain’s DNS service and it cannot be changed it only allows change to one of the following:
DNS Hostname (A)
DNS Hostname (Round Robin)
DNS Alias (CNAME)
The first two only accept IP address as input and #3 a domain.
So, can I use no-ip**.**com domains with Infinity Free?
Thank you.
You can’t use NoIP subdomains on free hosting, because they need to be a domain that you need to add, not a subdomain, if you want to change the nameservers.
If you registered your domain with NoIP, then you can’t add the domain as they must have to add the nameservers section to change the nameservers to our ones, or we may add a DNS adding domain system in the future.
