Hi,
In the free hosting how can we disable TLS versions below 1.2?
Can it be done using .htaccess file?
Thank you,
Dilshan
Hi,
Thank you,
Dilshan
You don’t have access to the full server configuration file on free hosting, and so can’t do that. If you had your own server, you could do that, but doing so would sacrifice the compatibility with some older browsers of your website.
Due to how SSL is done on our platform, we can’t practically change SSL parameters for individual domains or accounts. Meanwhile, like @Ergastolator1 said, there are still some older devices around which don’t support TLS 1.2 yet. These are getting fewer and fewer of course, but we would like to keep supporting them for a little more time.
Thank you to both of you for your answers and details.
Regards,
Dilshan
