epiz_31919552
To use the Digi Kavosh plugin, the allow_url_fopen feature must be enabled on your server.
epiz_31919552
allow_url_fopen should already be enabled. Can you run a PHP dump to prove it is not?
Maybe you can edit that plugin code so it recognizes or bypass that check altogether
Use of a nulled theme – the wp-vcd malware (or some other form like a trojan) in many cases comes pre-installed with every downloaded theme from nulled theme websites.
Thank you For that,
But the plugin is working and the error still exist.
I use the original theme.
sometimes I can not use Elementor in some pages…I don’t know why… it’s keep loading like forever.
Thank you.
How can I dump a PHP ?
Elementor is not recommended because of its heavy server resource usage. It can lead to unknown errors and quick suspensions.
Create a php file on your website and put this in it (should be the only contents):
<?php phpinfo(); ?>
And either share the url or somehow share the full contents of the output.
So I should stop using Elementor ?? unless my account will be suspended ?
I used that before and it was good so far… like 2 yrs ago.
The function is enable ! and plugin is working well, it just show an error to enable the function. looks like plugin has a problem.
whats your suggestion for Elementor !
Thanks in advance!
If it is working for you, and you are not suspended regularly, I think you should not feel obligated to discontinue its use.
